S: Nya Msd Delar!
zakspeed escort
S: Nya Msd Delar!
2st MSD högtrycks bränslepumpar till salu klarar cirka 500 hk/st.
Info
Vendor MSD Ignition
Product Line MSD High Pressure Electric Fuel Pumps
Free Flow Rate 43 gph
Maximum Pressure (psi) 80
Inlet Size 3/8 in.
Inlet Quantity Single
Inlet Attachment Hose barb
Outlet Size 5/16 in.
Outlet Quantity Single
Outlet Attachment Hose barb
1st MSD 6A tändförstärkare
Info
Vendor MSD Ignition
Product Line MSD 6A CD Ignitions
Ignition Box Output Capacitive discharge
Circuitry Analog
Rev Limiter No
Timing Retard None
CD Voltage Output to Coil 460-480 V
Current Draw 1 amp per 1,000 rpm
Spark Output (Millijoules) 115 Millijoules
Minimum Operating Voltage 10 V
Maximum Operating Voltage 18 V
Length (in) 8.00
Height (in) 2.25
Width (in) 3.50
Ignition Box Color Red
CARB EO Number D-40-33
1st MSD Blaster SS tändspole
Info
Vendor MSD Ignition
Product Line MSD Blaster SS Coils
Universal Yes
Coil Wire Attachment Male/HEI
Coil Style E-core
Coil Internal Construction Epoxy
Maximum Voltage 40,000
Turns Ratio 70:1
Primary Resistance .355 ohms
Secondary Resistance 4.40K ohms
Inductance 6.9 mH
Peak Current 300 mA
Spark Duration 220 uS
Mounting Bracket Included No
Coil Wire Included No
Ballast Resistor Included No
http://www.ultimatesaab.com/upload/msd-2225.jpg
http://www.ultimatesaab.com/upload/msd-6200.jpg
http://www.ultimatesaab.com/upload/msd-8207.jpg
Bränslepumpar 1500/st
Tändförstärkare + spole 3000:-
Prylarna kan skickas med bussgods, köparen betalar frakten.
OBS allt är nytt i kartong.
Info
Vendor MSD Ignition
Inlet Size 3/8 in.
Info
Vendor MSD Ignition
Circuitry Analog
Rev Limiter No
Timing Retard None
Length (in) 8.00
Height (in) 2.25
Width (in) 3.50
Info
Vendor MSD Ignition
Universal Yes
Coil Style E-core
Turns Ratio 70:1
Inductance 6.9 mH
Peak Current 300 mA
zakspeed escort
