S: MSD Turbo tändning
hismon racing
MSD-6462 $391.88
OverviewBrand: MSD Ignition
Product Line: MSD 6-BTM CD Ignitions
Ignition Box Output: Capacitive discharge
Circuitry: Analog
Rev Limiter: Yes
Timing Retard: One-stage
CD Voltage Output to Coil: 460-480 V
Current Draw: 1 amp per 1,000 rpm
Spark Output (millijoules): 115 Millijoules
Minimum Operating Voltage: 10 V
Maximum Operating Voltage: 18 V
Length (in): 8.00
Height (in): 2.25
Width (in): 4.000
Ignition Box Color: Red
CARB EO Number: D-40-26
Quantity: Sold individually.
Maximum power, no detonation risk.
Ignition Box, MSD 6 BTM, Analog CD, Boost Timing Master, Blown/Nitrous, Red, Each
The MSD 6-BTM CD ignitions are ideal for engines with a turbo or supercharger. Not only will they benefit from full power CD sparks, but there is also an adjustable boost/timing retard circuit to prevent detonation. The dash-mounted control knob lets you easily adjust the amount of timing retard from 0-3 degrees per pound of boost pressure. Dial away engine-damaging detonation by retarding the timing in relation to boost pressure, and run on the threshold of detonation for maximum power and efficiency. You also get overrev protection from the soft touch rev control. They work with 4, 6 (even fire only), and 8-cylinder engines using a distributor. They include rubber shock mounts and 3,000, 6,000, 7,000, and 8,000 rpm plug-in rev limit modules.
Säljes för endast 3700:- ny. Finns i Malung kan skickas hela landet
0280 10962 073 9892387 Jan
Circuitry: Analog
Rev Limiter: Yes
Length (in): 8.00
Height (in): 2.25
Width (in): 4.000
