S: MegaSquirt Wiring Harness - 12 feet long
tweaker
Inlägg av tweaker »
* IAC and Ignition wire have been added for MS-I or MS-2 use
* 12' of TXL High temp automotive grade wire.
* Color coded with labeling printed on the wire every 3 inches -- no paper tags here!
* Shielded Ignition input wire to cut out interference
* All wiring is pre-crimped (NOT solder cupped!) to the DB37
* Heavy duty AMP metal DB37 hood for superior RFI/EMI shielding (no cheap plastic 'metalized' hoods used on our harnesses)
* Wiring diagram included (pinout below)
* Simply the best MegaSquirt harness available anywhere, at any price (and our price is actually pretty low)
Note that the Wiring Harness and Relay Cable are 'mutually exclusive', meaning they are not designed to be used together. If you are using the wiring harness then you are wiring everything directly back to the DB37 on the ECU with relays and fuses where needed. If you are using the Relay Cable you are connecting the DB37 on the ECU to the Relay Board directly (so there is nowhere to plug the harness in anymore) and you then wire everything directly to the screw terminals on the relay board. Our Wire Bundle comes in handy for installation with a Relay Board.
Finns i Sjöbo,Skåne
Pris: 400kr plus frakt.
Den är aldrig använd.
Mvh.
Pris/utgångsbud: 400
Plats/närmaste stad: Sjöbo
Mathias-D
Namn: Mathias Dahlström
Medlemsnummer: 313
Inlägg av Mathias-D »
SÅld!!
