k. FEEET tändspole
- ErikJ
- Namn: Erik Johansson
- Medlemsnummer: 249
k. FEEET tändspole
passande sierra cossy
0708777860
msd eller liknade
0708777860
msd eller liknade
- cosworth540
- Namn: stig terje rosenvold
- Kör: Sierra Cosworth rwd,Sierra RS Cosworth 86 rallybil.2001 Mondeo combi
tändspole
kan skaffa dig den här.700 kr +frakt
PROCOMP 2041-R IGNITION COIL
THE MOST POWERFUL TYPE COIL YOU BUY. E-CORE STYLE. THIS COIL HAS BEEN OUR NUMBER ONE CHOICE FOR YEARS. THIS IS THE NEWEST MODEL ON THE MARKET. NOTICE THE FINNED ALUMINUM COVER. THE FORMER MODEL DID NOT HAVE THIS FEATURE. THE FINNED ALUMINUM CASE DISIPATES HEAT MUCH BETTER THAN THE NON FINNED STEEL COVER.
EXCELLENT FOR THOSE RUNNING AN MSD 6A OR 6AL. THIS COIL IS ALSO WELL SUITED FOR THOSE WITH EFI OR TBI LATE STYLE DISTRIBUTORS 1987-UP. EARLY FORDS WITH ELECTRONIC IGNITION WILL BENEFIT GREATLY WITH THIS COIL. THE FACTORY COIL IS FAR TO SMALL TO PROVIDE SUFFICIENT SPARK FOR OPTIMAL PERFORMANCE. THIS COIL IS FLAT SURFACE MOUNT. CHRYSLER ELECTRONIC IGNITIONS ARE WELL SUITED FOR THIS COIL. GREAT FOR FIREWALL OR PLATE MOUNTING.
THE COIL WEIGHTS A MASSIVE 3LBS. THAT'S THREE TIMES WHAT THE OEM STYLE GM COIL WEIGHS. FOR THE VERY LOW PRICE WE ARE OFFERING THIS COIL, IT'S A MUST. ALL COILS ON THE MARKET HAVE WENT TO THIS DESIGN, BUT MOST HAVE A FAR LESS VOLTAGE OUTPUT.
DODGE AND GM IN THE LATER YEARS STARTED USING A SIMIULAR COIL ON THE COMPUTER CONTROLLED CARS. THOSE COILS ARE TERRIBLE, AS THEY ARE JUST TO SMALL. AFTER A FEW YEARS THEY LOST A LARGE PERCENTAGE OF THEIR FIRE POWER. FORD CARS WITH THE BOTTLE STYLE COIL, ARE IN THE SAME SITUATION.
THOSE RUNNING A BOTTLE STYLE COIL WOULD DO WELL TO UPGRADE TO COIL. MODIFIED ENGINES HAVE A HIGH DEMAND FOR HIGH VOLTAGE SPARK. GM NOW USES COIL ON PLUG TECHNOLOGY ON MANY VEHICLES. THEY HAVE INCREASED THE VOLTAGE ON THESE COILS 3 TIMES SINCE THE INCEPTION OF IT'S USE. LATER MODELS HAD COOLING FLANGES ON EACH COIL DUE TO THE HIGH OUTPUT. MOST ALL AUTO MAKERS HAVE WENT TO THIS TYPE IGNITION. A CONVENTIONAL BOTTLE STYLE COIL, CAN'T COMPARE TO THIS.
SPECS,
2041-R High Performance Coil
Producing up to 70% more spark energy than stock coils with outstanding reliability.
This unit is recommended for street, strip, circle track and drag racing.
The coils uses "E-core design" technology which loses less voltage so more spark gets to your plugs.
Internally the coil also has large gauge wire windings for maximum spark current and voltage with better heat dissipation at high rpm.
High voltage arcing is minimised through screw on connectors and a high tension tower.
Ideal for use with capacitive discharge (CD) ignition systems and all of Procomp range of High Output Ignitions, as well as any electonic ignition setups. This coil is a must!
SPECS,
- ErikJ
700 svenska kronor? vad kan frakten kosta då?
- cosworth540
- ErikJ
upp... då jag inte hann betala pezon innan han sålde den
