Adaptiv in lärning vid bytte av spridare?,Ford focus 1.6 tdci 115hk -12
Chris123
- Namn: karlborg christian
- Kör: Ford focus 1.6 tdci 2011
Har bytt 2 st spridare på min focus 1.6 tdci. efter byttet knackar motorn och går ej helt 100..
Har en FORscan (OBD verktyg) har fått fram att man ska nolla injectorerna och där efter köra in dom .
Är det någon som har med framgång lyckats med inkörningen?
Mina värden sitter fast på noll (ska gå från noll till sju)
Saxat från ett utländskt forum
1.3rd 4th 5th or 6 gear
2.Over 40 km/h
3.Deceleration repeatedly from 2500rpm to 1500rpm for 20 km (we ended sooner)
I asked him to let me take a picture with the page he was on and he refused me. He told me to write down the 3 steps above but no pic...☺
There were several stages he must complete to have all the injectors learned - initially all 4 were red with a big 0 on. During the cycle each injector changed the 0 value to other value (3 4 5...don't remember) till finally reached 7 and turned green. Learning complete. He repeated this cycle until all 4 were on 7 and turned to green.
So guys if don't have an IDS clear /reset those adaptations and do EXACTELY as described above , as the learning is only applying when decelerate. He eplained that to me. He told me that the car was better after learning performed by me but not best because i didn't follow the procedure.
I asked him how can i do it myself next time and he told me that without IDS i will not know when the process is complete. Then i asked him what if i'm driving for 30 min as he did (2500 to 1500 and back to 2500 and back to 1500 and so on) and he smiled telling me that YES if you do that you will learn the values correctly for sure because the learning process took about 10- 15min to complete. With other words without IDS just to be on the safe side make it double...30 min up and down and the learning will complete.
2.Over 40 km/h
