Tändningsström
marblu
- Namn: Martin
- Kör: Mondeo
Tändningsström
När jag kom ut till bilen (Mondeo 2004 2,0) så startade den inte, har felsökt startmotor (funkar), batteri nytt), får ingen gnista, saknar tändningsström.
Tändspole (funkar). blinkar i klockan med tändning på blink paus blink paus och så håller det på.
Har ström till startmotor även vid tändning.
Går ej att starta med startkablar eller bogsering.
Ford har inte en aning vad felet kan vara, hoppas att någon här kan veta:)
Med vänlig hälsning. Martin
Har du kollat med en felkodsläsare?
Annars ska man tydligen kunna utläsa koden från blinkningarna:
Mondeo PATS system
When the PATS LED is flashing continuously the vehicle will not start, try locking/unlocking driver’s door lock with key or remote & then try ignition again
Check DTCs (Diagnostic Trouble Codes) on your vehicle using flash codes
PATS LED INDICATOR
The LED indicator is used for the PATS system and also other Anti-theft systems fitted to the Ford vehicle range.
When the ignition is switched ON, the PATS LED will illuminate for 3 seconds while it performs a self-test, after which it extinguishes.
When the PATS system is armed, and the vehicle is immobilized, the PATS LED will flash quickly.
If there is a fault on the PATS system, and the engine can start, the PATS LED will illuminate for 60 seconds continuously, and then flash the PATS fault code 10 times.
If the engine is unable to start and disabled by the PATS system, then the PATS LED will FLASH for 60 seconds and then flash the PATS fault code 10 times.
PATS LED is mounted either in the front headlining or next to the heater controls/clock.
The PATS system has its own self diagnosis test procedure which
flashes codes. The PATS LED will flash quickly for 1 minute, and then
start flashing the fault code as follows:-
Example: code 31
3 Flashes + 1 Flash
Three seconds delay
Repeat of code for 10 times
Code Descriptions:-
Code 11 Transceiver not connected
Code 12 Transceiver
Code 13 No key data received
Code 14 Part of the transponder code received
Code 15 Wrong transponder key
Code 16 Faulty link between PATS module and EECV
Code 21 Less than the minimum keys required programmed
Code 22 Failed diesel pump control unit identification
Code 23 The response code between pump control unit & power train
Code 32 no response from the fuel shut off solenoid valve on the fuel injection pump
LED = Always ON or OFF
Check the fuse 15 (5 amp)
Mondeo PATS system
PATS LED INDICATOR
Example: code 31
3 Flashes + 1 Flash
Three seconds delay
Code Descriptions:-
Code 12 Transceiver
marblu
- Namn: Martin
- Kör: Mondeo
nu är blinkningarna borta men bilen startar inte ändå. Det klickar fram vid luftslangen och där det sitter 2st gaswirar typ någon gasspjäll med ett svart kontaktstycke så fort jag slår på tändning.
sitter larmmodulen vid handsfacket?? tänkte koppla ur den eller bygla för att utesluta att det är den som stör.
