Lambdasensor
Goofy
Namn: Jörgen Hedman
Kör: Husaberg FE 570
Lambdasensor
Inlägg av Goofy »
Hejz
Ska precis montera en Innovate LC1 och funderar på om man kan ta signalen från den o stoppa in i ECU? Någon som gjort detta?
6. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connected
to the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one or
both of these wires are not being used isolate and tape the wire(s) out of the way. The default
analog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This is
a simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39
AFR. Note: The LC-1’s heater ground and system ground wires should share the same
grounding location of the analog input’s ground. Refer to chapter 2.2 for recommended
wiring schematics.
Its nice to be important, but its more important to be nice!!
motorcraft
Namn: Jörgen Jacobsson
Kör: Cosworth Rwd & Sierra GT
Medlemsnummer: 25
Inlägg av motorcraft »
japp de kan du, och då är analog 1 förprogramerad för smalband så de är den du ska använda dig av.
Mvh
