Scorpio går upp i temp
fordmaffian
Namn: Robert Åhlin
Inlägg av fordmaffian »
ahh okej.. ja då är de ju jävligt mysko men slit bort termo staten och fixa till så att fläktarna går igång då kan den ju inte bli varm.. men visst bilar kan göra så att en får huvudvärk.. :banghead:
Någon som har en idé om hur jag ska få igång fläktarna då? Hade varit smidigt om det vore som på Scorpio -94an jag har ståendes. Bara slå på ACn om hoppas fläktarna igång.
Vart sitter givaren till fläktarna?
fordmaffian
Namn: Robert Åhlin
tror att de kan stå någonting här: http://www.fordscorpio.co.uk/
fordmaffian
Namn: Robert Åhlin
All Scorpios made between 1994 and 1998 achieve the cooling of the radiator by means of an electrical two speed twin fan system. Unlike other cars (for example the Mercedes W124), the same fans are also used to cool down the condenser while the air conditioning system is running. Depending on the engine type, the fans can be controlled either by a thermal switch mounted on the radiator (2.9 12V or 2.5 TD), or by the PCM (DOHC2.0 8V and 16V, DOHC2.3, Cosworth 2.9 24V).
One point should be clear right from the beginning: both fans must either run simultaneously or not run at all. You should never have only one running fan.
Also, the fans only work while the engine is running. They must never stay on after stopping the engine, like in other cars (e.g. some Renaults).
Since the cooling fans are also used for air conditioning, they run on low speed whenever the A/C is on, regardless of the engine temperature. If they run on high speed with the A/C on while the engine is cold, this indicates a refrigerant pressure problem.
The fans work as follows:
• Engine stopped => both fans off
• Engine cold, A/C off => both fans off
• Engine cold or warm, A/C on => both fans running on low speed
• Engine hot, regardless of A/C => both fans running on high speed
fordmaffian
Namn: Robert Åhlin
SYMPTOM
Neither fans run at all:
Check fuse F37
Check Fans relay R34
Check Fans multiplug for 6V and Ground
Check ECT (Engine Coolant Temp sensor) for varying resistance - lower when hot (see ECT and Data) note: ECT does not provide voltage for instrument panel engine temp gauge - this is a separate sensor
Only one fan runs at high speed when hot:
Check Fuse F44 and F39
Check wiring and multiplugs
Check fan not running for 12V and Ground
fordmaffian
Namn: Robert Åhlin
For the EECV-equipped cars, (the two DOHC 2.0L models, the 2.3L and the 24V) there is no temperature switch. In fact the fans are connected in series in usual use, sharing six volts each which results in the low speed running. There is no fan thermister switch - instead the temparture of the coolant is sensed by the EECV Powertrain Control Module via the ECT.
The following is an explanation of the coolant fans circuit
On the above diagram you can see the wiring path that is used when the fans run in slow speed
fordmaffian
Namn: Robert Åhlin
On the right hand side of the circuit you can see there is a permanent supply through fuse 39 into the first fan. The relay is open so both fans are off.
When the PCM wants the fans to run slow it energises the relay by grounding pin 68 to earth. The relay has a switched live feed to its coil from the ignition switch. This prevents the fans coming on if the ignition is off.
When the relay is energised the contacts close and the two fans are connected in series. This means that the 12v supply is split evenly between the 2 fans and so they get 6v each. This is what makes the fans turn slowly.
This diagram is for all cars except 2.9 12v and diesel. They have a 3 way temp switch, Normal, Temp1, Temp2. The circuit is the same but uses this switch instead of the PCM.
FANS ON HIGH SPEED
denna informationen är hämtad från den sidan
fordmaffian
Namn: Robert Åhlin
"The first fan’s plug is located below the fan, very close to it, and can only be accessed from beneath the car, after removing the undertray.
The second fan’s plug is located near the fan and to the right (as seen from the front to the back of the car). It can be easily accessed without raising the vehicle, but you have to remove the resonator box first."
Om de är detta de menar med givare så har du svaret här.. annars vet jag inte..
Tack för det Robert!
fordmaffian
Namn: Robert Åhlin
var så god! hör gärna av dig emellan åt hur de går:cool:
Vill fortfarande veta vart givaren till fläktarna sitter :).
fordmaffian
Namn: Robert Åhlin
Järnkaminen skrev:Vill fortfarande veta vart givaren till fläktarna sitter :).
Den första givaren ( Plug=Givare? tror jag det betyder? ) är brevid den vänstra fläkten på vänster sida, antagligen på kylarens gavel? den andra givaren= "plug" sitter på höger sida om fläkten, antagligen också på gaveln på höger sida från frontens håll sett, men du måste ta bort insugs ljuddämparen för att se den.... Så förstog ja texten iaf, rätta mig om jag har fel någon??:confused:
fordmaffian skrev:The first fan’s plug is located below the fan, very close to it, and can only be accessed from beneath the car, after removing the undertray.
Nej sitter inga givare på kylaren.
fordmaffian
Namn: Robert Åhlin
de än nu man ångrar att man skolkade på engelskan....:banghead:
fordmaffian
Namn: Robert Åhlin
http://www.fordscorpio.co.uk/manual/eng ... 16vECT.pdf här ser du var den kan finnas.. hittade inge lätterar tyvärr..:banghead: än iaf:)
