How-to: Bromsluftning, Performence Probe style!
Hur man luftar Bromsar på Performance Probe vis! :D
Think he needs help on brake bleeding. Its sooo much fun <sarcasm>. I'll assume you have the caliper remounted.
1) Find a unsuspecting sucker. For this exercise, we'll call him "a friend".
2) Play Paper, Rock, Sissors to decide who gets to wrench and who gets to sit in the car.
3) Fill a mason jar 1/2 full with brake fluid. Attach a piece of hose to the bleeder fitting on the caliper (looks like a little nut with a nipple on the end) and submerse the other end into the mason jar.
4) Whoever lost and gets to turn the wrench needs to loosen (NOT remove) the bleeder screw.
5a) The winner of P,S,R sits comfortably in the car lets the sap with the wrench know he's pushing the pedal. Then depresses the brake pedal fully and holds it to the floor. Once its held to the floor, yell to the poor bastard to tighten the bleeder screw. When the schmuck tells you that the bleeder is tightened, release the brake pedal.
5b) While the pompus ass sitting in the car pushes the wee little pedal, observe the end of the tube submersed in the brake fluid for bubbles. When "his majesty" says he has the pedal fully depressed, tighten the bleeder screw and yell back that the bleeder is tightened.
6) Repeat steps 4 and 5 until there are no more bubbles coming out of the tube in the mason jar. At this point, this caliper/piston is done...only 3 more to go. Make sure to keep an eye on the master cylinder resivior as well...do NOT let it run dry.
Papillon
Namn: Johan
Kör: Audi A4 Ts -07
Inlägg av Papillon »
hehehe känner igen det där =)
//Johan
Skruvlös
Namn: Sven L
Kör: Buss
Inlägg av Skruvlös »
hemska minnen... sysslar me bromsar nu så man e lite skid att man måste göra det :P
