S: H3 55W Pro Max HID Xenon Conversion Kit 6000K
tweaker
Inlägg av tweaker »
HIDS4U now have a 55W type HID kit available! This kits is the brightest kit we have come across! The ballasts are rated at 55W instead of the standard 35W on other HID kits. This extra power gives an additional 100% more light than the 35W kits.
As you would expect from HIDS4U, the quality of the kit is superb with the ballast being completely waterproof. It also works on 99% of vehicles including those that have bulb out warning lights.
K Ratings
4300K yellowish white (OEM fit)
5000K crystal white with no blue tint
6000 crisp white light with delicate to moderate blue tint
8000K blue light
We have been driving with HID Xenons now for many years and as you may have guessed we have tested every combination of Kit, bulb and colour. The following is a summary of our findings (objective as we have used light meters to measure the actual light outputs) and recommendations (both objective and subjective), which most customers agree with:
We have tested dozens of bulbs and compared them all to a Philips D2S bulb as a reference point. The difference between manufacturers is really quite shocking. The best 6000K bulb produced only 15% less light than the Philips 4300K - while the worst 6000K bulb was a dreadful 70% less. That said, our bulbs being the best ones with 15% less light in measurable terms, actually produce a very white light with a slight blue tinge to look at. For every day driving this really is a more pleasant light than the yellower 4300K.
If your after the coolest looking Xenons with amazing performance then 6000K is our recommendation.
Please remember that the blue tint is not produced by the bulb, but by the reflector/projector lense. Refraction spilt the colour of the light like a Prism if you remember that experiment from Physics. 8000K bulbs or higher are not the answer - they produce less light and you are more likely to be noticed by the Police.
One last thing as we have proved by testing, not all manufacturers colour ratings are the same, so please dont try to compare! Some claim 12000K is sky blue!! Wrong - should be purple!!
Nypris: 149 pund plus frakt.
Säljes till högsterbjudande.
ALDRIG ANVÄNDA!
Mvh.
Pris/utgångsbud: 1000
Plats/närmaste stad: Sjöbo
tweaker
Inlägg av tweaker »
UPP!
Behöver ni bra ljus?
Ta detta kittet.
tweaker
Inlägg av tweaker »
UPP! Nu då.. Behöver lite cash.
jonns
Namn: magnus jonsson
Kör: volvo,sierra cosworth,punto gt
Medlemsnummer: 77
Inlägg av jonns »
lite oförstående,men vad kan du sättA detta i för lysen???
tweaker
Inlägg av tweaker »
Var du vill där du har H3.
Extraljus, Dimljus, Vanligt ljus.
Det som är det bästa är att foten till lampan är gjord av "gummi" så man kan lätt modifiera den till Typ H1 som finns på Escort.
Själv har jag 35W kit i halvljus, 55w i helljus.
Lyser som bara den.
Skulle ha detta kittet i dimljusen men 55w blev förmycket. Så skall skaffa ett 35w istället där.
Mvh.
