S: Cosworth parts
sirmark
Namn: Mark
Kör: Ford
S: Cosworth parts
Inlägg av sirmark »
Collins Performance -31 actuator
Blue, fits T34/T35 Turbo on 4wd exhaust manifold
Very little use.
£45
Kent Cams BD16+ camshafts
A set of almost new genuine INA followers
Inlet and Exhaust
Only run 2500 miles
Excellent condition !
£220
BAILEY DUMP VALVE DV24
Silver
£25
Garrett Genuine ISO Heat Shield Cover
Never been mounted since it does not fit on my car because the turbo sits very close to the cylinder head.
It is for external wastegate not internal as illustrated.
http://webshop.nordicturbo.dk/products/ ... ItemID=407
£150
Garrett GT35R - Polished
Turbine 1,06
V-band for exhaust
Only done 500 miles, excellent condition !
£700
Accralite pistons
92mm bore, 7,7:1
run 15500 miles.
http://www.accralite.com/accralite/imag ... 60xc92.jpg
£150
Escort Cosworth throttle body (big turbo), incl pot-meter and ISCV
£50
8x Genuine FORD Sodium filled COSWORTH YB exhaust valve
8x Genuine FORD COSWORTH YB inlet valve
Only done 125 miles !!!!
Only reason for selling is because I have upgraded to large valves
£550
RC injectos
750ml, high-ohm
Only done 125 miles
£340
Pris/utgångsbud: look
Plats/närmaste stad: Denmark
